Toshiba e222CS/ e263CS
    • 8228
    Does anyone have any experience with these new relabelled Okidata machines available in Europe and Australia?
  • Northwestservice
    • Jan 2011
    • 140
    Re: Toshiba e222CS/ e263CS
    what is it you are looking for?
      • 8228
      Do they work well? What is the Colour quality like? Do customers like them? Are they noisy when operating? Is the control panel easy to use?
      • sdrawkcab
        Confused & Bewildered
        • Jun 2009
        • 317
        Yes, Pretty good, Yes, Not to bad, It's ok once you get use to it.
        I've installed around 20 of them as USB and network, no negative feedback from customers, CQ seems fine on it's own, they are fully featured and even do banners (narrower) than the Toshiba range, the print setup is very easy, the scan setup is a little different but you get there in the end, the display is tiny but resonably laid out.
        Consumable cost might be an issue if you put them on a copy plan. All of ours are on a chargeable basis.
        Some days, it's just not worth chewing through the restraints
