Help me fix C440 error in E 355 !!!!!!!!!!!!! .............. serious problem
  • minhkhanh
    • Oct 2008
    • 60
    Hi every body,
    I cleared the error with code 08-400 ( error 5 ). The Machine still error again after reboot
    I tested on another machine and sure fuser unit and power supply works well.
    The problem in LGC board, ( The ROM on it work well ).
    Any one help me fix that error !!!
  • Meach
    • Nov 2008
    • 128
    Re: Help me fix C440 error in E 355 !!!!!!!!!!!!! .............. serious problem
    TSB-1013.pdfTSB-1036.pdf
    • minhkhanh
      • Oct 2008
      • 60
      Originally posted by Meach
      [ATTACH]11470[/ATTACH][ATTACH]11471[/ATTACH]
      I do it that way but not success, Do you have another way?
      whether newer firmware can solve the problem?
      • michaelc
        Field Tech
        • Mar 2011
        • 590
        So the fuser and the psu worked in another machine?
        It didn't say that I couldn't do it in the manual.
        • minhkhanh
          • Oct 2008
          • 60
          Yes,
          • michaelc
            Field Tech
            • Mar 2011
            • 590
            if your thinking its the logic board could you try that on another machine to check it out? Check the PSU to maybe. Firmware is always a good idea on the machines.
            • minhkhanh
              • Oct 2008
              • 60
              I tried LGC on another machine, but still does not work.Errors have been confirmed in LGC
              I tried up firmware, but still does not work
              • michaelc
                Field Tech
                • Mar 2011
                • 590
                Have you tried the power supply board?
                • minhkhanh
                  • Oct 2008
                  • 60
                  In this case, what components on the LGC is damaged?
                  • smiley
                    • Aug 2008
                    • 616
                    some of those ic on the logic board is busted the only way is to replace it. i see this before on the older estudio copier those who are 35 and 45 ppm.
                    there is no glory without sacrifice
                    • minhkhanh
                      • Oct 2008
                      • 60
                      Do you know exactly which IC ?
                      • minhkhanh
                        • Oct 2008
                        • 60
                        Need help
                        • minhkhanh
                          • Oct 2008
                          • 60
                          Helppppppppppppppppppppppppppppppp
                          meeeeeeeeeeeeeeeeeeeeeeeeeeeeee
                          • michaelc
                            Field Tech
                            • Mar 2011
                            • 590
                            I see it you have swapped the logic board and fuser from the broken machine to another and those parts worked on the other machine. Have you tried the power supply board?
                            When you get the code C440 is the fuser warm, hot or cold?
                            • minhkhanh
                              • Oct 2008
                              • 60
                              As I saild from begin
                              I a swapped Fuser unit, power supply and LGC board one by one
                              And sure the problem in LGC
                              when machine get error, the fuser is hot ( but not hot enought )
