Toshiba E-Studio laser codes
  • Navy
    Brown Shoe Sailor
    • Jul 2006
    • 47
    Does anyone have information on a bulletin from Toshiba dealing with laser fault codes on older Toshiba E-Studio machines? someone told me about an added ground in the laser harness but after looking at it i'm not sure where.
    NAVY - Never Again Volunteer Yourself
  • ToshibaGuy
    • Jan 2005
    • 77
    This was on Toshiba's site for the eStudio28/35/45 also look at the attached file that talks about the permanent fix.
    hope it helps, good luck
    CA1 AND CA2 ERROR CODES
    If the machine is getting these error codes, make sure the system is at version 11 firmware or later. Then monitor the performance of the copier with 08 code 479 set to 1. This code relaxes the critera used to declare a CA1 error. If the problem continues to occur, you might need to replace the laser.
    • Navy
      Brown Shoe Sailor
      • Jul 2006
      • 47
      thanks for the help, I will take a look.
