CF90 on a 3500c
  • repeatcopiers
    • Sep 2008
    • 591
    CF90 on a 3500c
    I believe this code is a laser shutter error, but can someone tell me how to repair this? We mainly service Canon so I'm not that familiar with this copier, but would love to keep this customers business....especially in this economy!
  • Gregg
    Re: CF90 on a 3500c
    To counteract CF90 (laser optical unit shutter) errors, the finishing level for the stud of the motor bracket has been improved so that the gear of the shutter motor can make smoother vertical movement.
    Detail
    The modified bracket has been applied to machines manufactured since May 2008.
    e-STUDIO3510c Series, e-STUDIO4520c Series 36-15 6LE22655000
    ASYS-PL-MOTR-SHUT-D-2
    6LH32963000
    ASYS-PLTSHT-45X
    • tech07
      • Aug 2008
      • 410
      Re: CF90 on a 3500c
      I'm currently fighting this intermittant code, but it's on an Estudio 2830c. Toshiba tech support said that the shutter motor bracket update was unessacary because it was for the previous 3510c series and my copier would already have it. My CF90 code is intermittant. Sometimes 3 or 4 times a day and sometimes once every couple of days..iN 03/417 mode, the shutter will operate fine. Has anyone had to change the shutter motor itself ? or the shutter sensor? It's not an easy task pulling this unit as i have already done it once..It would be great to have some input before I dive in again.???
      • Dredd
        • Feb 2012
        • 17
        Re: CF90 on a 3500c
        I've had this fault a few times. The fix was to remove the shutter assembly (pain in the arse), and to stick some mylar down on the parts where the shutter slides on the plastic so that it slides smoother. I've done this 4 or 5 times with success.
        • JustManuals
          • Jan 2006
          • 9838
          Re: CF90 on a 3500c
          Paul@justmanuals.com
