network setup toshiba estudio 452
  • remielee
    Technical Analyst
    • Mar 2010
    • 140
    guys can you help me of my problem about the network setup of toshiba estudio 452, how can i setup the network on the mac os do you know the steps? please sir send me the steps, i already have the flash drive that come from toshiba company, do i need the driver cd? or it was already inside of that flash drive? i will wait for all your reply guys? all your help would be appreciated. thank you in advance more power to you guyss...
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: network setup toshiba estudio 452
    install thumbdrive into copier (power off behind cover next to network jack)
    power on machine and go into admin mode
    set network settings
    Download driver from Drivers | Support | Toshiba Copiers
    install as printer
    • remielee
      Technical Analyst
      • Mar 2010
      • 140
      install as printer
      thnk you sir about the reply.wat do you mean that i will insert the flash drive into the machine in tha right side of the machine then i will go to the admin mode then setup network after that installed the driver?
      • emujo
        • Jun 2009
        • 3009
        You brought this on yourself Mr Spock...go ahead answer the man...this is gonna be a long thread Should have used the standard answer..if you are completely out of your environment, hire a qualified tech to come out and do the work..sit on his/her shoulder and watch and maybe you can learn. Emujo
        • remielee
          Technical Analyst
          • Mar 2010
          • 140
          guys thnks for the replies on my problem, i already fix the network conectivity for mac os, i simply ask and search google then i find the steps now the machine and connection are working fine. thnks guys and more power..
