LAN Fax Driver
  • mfugate
    • Jul 2025
    [Misc] LAN Fax Driver
    Does anyone know where you can download a LAN Fax driver for a E Studio 5520c. Looked for a while now - need help!
    Thanks...
    • 8207
    Re: LAN Fax Driver
    Toshiba America, Inc.
    You have to download the eBridge Full Installer as a zip file. You then need to burn the ISO image to a CD. The Fax/ LAN Fax driver is located there. Latest version of CD is 2.10 . Latest firmware is V303.
    • mfugate
      Re: LAN Fax Driver
      Thanks for the help !!
      • lucky777
        • Oct 2007
        • 54
        Re: LAN Fax Driver
        Don,t use the old fax driver, its better to use the one for the Ebx series machines. Go to toshiba's main public site and download the fax driver for the 2540c.it works on all the prior ebridge version machines. Also the new Universal driver for that series works for printing on older series.
        • NSD
          • Aug 2011
          • 44
          Re: LAN Fax Driver
          I would advise using the new EBX Fax driver as it is the first toshiba Fax driver to work with a popup (like all other fax drivers) but don't use the new Universal driver unless you need to as its not finished yet.
          • mfugate
            Re: LAN Fax Driver
            Thanks again everyone for all the help. Got what I needed and everything is great !!
              • 8207
              Re: LAN Fax Driver
              NSD,please expand on the pop up feature.
              I assume you are not referring to a pop up blocker.
