hi, copier Toshiba E STUDIO-25 showing on display "Replace Process Unit", i've replaced the drum from the drum unit... the message is still on the display.. pls help me.
10x
If your machine is eStudio 25 (without s) and the firmware is not 1z or 1g that it's mean you required change all process unit (PU-KIT). Other wise you can use 08-673. but if your machine before that firmware, this program will not avalaible in there. You can upgrade this firmware by using Jig or PC downloader. But sorry I don't have this firmware again.
