toshiba es 452 c260 error
  • smiley
    • Aug 2008
    • 615
    hi guys can you help me pleased on this i know that this is a scanner error. but i dont know where to start.
    there is no glory without sacrifice
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: toshiba es 452 c260 error
    Check the lamp is working in 03 mode and getting the correct power etc. Firmware would not hurt either.
    It didn't say that I couldn't do it in the manual.
    • emujo
      • Jun 2009
      • 3009
      Peak Error detection...If the lamp lights at power on and carriage looks like it's going to the home position then it's probably gonna be a CCD/SLG assy. Emujo
      • mckinley
        Chief Twiddler
        • Dec 2006
        • 150
        If you take off the original glass & then switch on holding 0&3, switch the lamp on by keying in 267 & pressing start & then while the lamp is lit move the carriage by hand (you cant move it by code while another code is already running)
        while moving the scanner with the lamp lit, see if it goes out or flickers, if so then it's the ribbon cable from the SLG to lamp board. if it stays lit then SLG / CCD would be my next shot, but them ribbon cables do start to break down & cause C260 errors. :-)
        Happiness Is The Road.
        • smiley
          • Aug 2008
          • 615
          hi guys thanks for all the help.the lamp just light up then turn off when i turns on the power. then i replace the ribbon cable and on the slg board and now it ok thanks for all your help guys.
