E355 Skew from all cassettes-
  • tech07
    • Aug 2008
    • 410
    [Jamming] E355 Skew from all cassettes-
    E355 is feeding paper crooked as it's approaching the drum area..( crooked image) the paper is literally crooked. Sometimes jams E020. Image has just strted to print from drum . The copies that do make it out are skewed quite a bit.. Top tray will skew and jam almost every copy..Other 3 tray wont jam but are quite skewed.. I swithched feed roller units but do not see anything causing this..Any ideas??
  • Travis06
    Tech.
    • 193
    Re: E355 Skew from all cassettes-
    Did you check the long plastic piece that unfolds as you open up the whole right side of the machine. Those break or get mangled and do not alow the side to shut all the way.
