toshiba e-studio 160 coppier server print problem
  • pavlos_x
    [Misc] toshiba e-studio 160 coppier server print problem
    installed print server, also installed printer via tcp/ip same ip i see status that is printing and everything but still doesn't print
  • pavlos_x
    Re: toshiba e-studio 160 coppier server print problem
    Some help please?
    • UBIK
      • Jun 2011
      • 11
      Is there a printer card ga1030 (pcl)?
      If it's just printer gdi i think it's hard to make it work whit an external print server
      • pavlos_x
        ''Is there a printer card ga1030 (pcl)?
        If it's just printer gdi i think it's hard to make it work whit an external print server''
        printer card ga1030? network card you mean? i don't think so, why is to hard? is it possible though?
        • UBIK
          • Jun 2011
          • 11
          I am not referring to the network card (gf1011)
          If the printer button (right of the screen) lights means that the printer card (ga1030/31) is installed. Estudio160 with ga1030/31 is able to understand the printer language PCL . In this case I would try to install hp laserjet 8150 pcl driver compatible, use the lpr protocol (if I remember correctly the raw protocol on port 9100 does not work) in the print queue.
          If the toshiba also has the network card gf1011 should be any problems even with Win7 64-bit.
          If the card is not present, and then the Toshiba is a simple gdi printer I do not know brands of external print server capable of supporting it.
          To print on estudio160 with a external print server or with your network card is almost mandatory to have the ga1030/31.
          • pavlos_x
            ''I am not referring to the network card (gf1011)
            To print on estudio160 with a external print server or with your network card is almost mandatory to have the ga1030/31.''
            Printer button (right of the screen) doesn't light so i guess i have a big problem! so i have to find a compatible print server? or i have to find drivers to install ga1030/31?
