Error CD30 on est 850
+ More Options
Posts
  • same_steven
    • Jun 2011
    • 52
    Hallo everyone,
    I have an Est850 that keeps displaying "Toner not recognised" though the toners are original and
    then its toner recycling process has failed and after using it for a while it gives error CD30.
    I have to open the toner recycling unit and manually pour out the used toner.
    on its cassette 3,if you open it to add papers, it does not lift unless you restart the machine.
    Rgds,
    Same_Steven
  • JustManuals
    • Jan 2006
    • 9838
    Re: Error CD30 on est 850
    Paul@justmanuals.com
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      Is the toner cartridge rotating and all the connectors on the toner unit in properly?
      It didn't say that I couldn't do it in the manual.
      • scotjohn
        • Dec 2008
        • 15
        could be the top half of the front door is not making the microswitch , open front cover and cheat the front door switched.
        • same_steven
          • Jun 2011
          • 52
          the door sensors are working ok. is there a way of testing the toner sensors?
          • tech-wazza
            • Dec 2007
            • 7
            Have you tried checking the recycled toner transport auger?
            If this blocks up and jams you can break the auger or jam the motor which will give this error.
