Continous feeding on Est 181
  • same_steven
    • Jun 2011
    • 52
    Hallo friends,
    I have an Est 181 that is giving paper jams on the second copy (continuous feeding) at the registration rollers.
    I have changed the registration clutch and the selonoild of the pick up rollers but still the problem persists.
    When i use the bypass tray i don't have any problems.
    what could be the problem?
  • michaelc
    Field Tech
    • Mar 2011
    • 590
    Re: Continous feeding on Est 181
    The cassettes/trays are poor on those models. Order a kit with the claws (sep) in as the sometimes get deformed from customers slamming paper in like they are trying to win a prize. What jam code are you getting?
    It didn't say that I couldn't do it in the manual.
    • same_steven
      • Jun 2011
      • 52
      the jam error is E13
      • michaelc
        Field Tech
        • Mar 2011
        • 590
        That is a jam from the top cassette. I would change those sep claws and check the cassette frame is not cracked to.
        • same_steven
          • Jun 2011
          • 52
          the problem was that one of the feed rollers had its lock broken. you know the lock just next to where you put the screw.
          Problem solved.
