e-166 printer output
Tags: None
Re: e-166 printer output
I would completely uninstall the printer and add it again.
First determine which print driver you need,
From this site :Toshiba - Photocopiers, printers and fax
Identify the installed controller
This machine can use built-in GDI printing or it might have the optional GA-1190 or GA-1191* controller installed.
Press the PRINTER hard key on the control panel. If a GA-1190/1191 controller is installed, the resulting display will display a number of selectable Menus. If there is no response to the PRINTER key, then the GA-1190 or GA1191 is not installed.
Use the Viewer Full Installer for GDI printing if a GA-1190/1191 is not installed. If a GA-1190/1191 is installed, you can use GA-1190/1191 or Universal drivers. You cannot use Viewer if the optional GA-1190 or GA1191 is installed.
