Toshiba E351C networking trouble.
+ More Options
Posts
  • yormets
    • May 2009
    • 336
    I have one of these where the TC/IP is disabled in the NIC report. So are the others. Is there a wat y to enable them . The only way I can print is with windows 7 through a samba port. Huh?
  • didi2005
    • May 2011
    • 401
    Re: Toshiba E351C networking trouble.
    Press User FUnction--> Admin--> Default PW "123456"-->Network--> enable the TCP/IP
    • TheOwl
      • Nov 2008
      • 1732
      If TCP/IP is disabled, then technically you shouldnt be able to print to the device unless Windows has something like Bonjour installed.
      Follow the post above to get TCP running on the copier and set up your print queues for TCP/IP printing.
      • yormets
        • May 2009
        • 336
        I had to reinitialize the NIC. Everything came back up.
