Networking an E351C
  • yormets
    • May 2009
    • 336
    Networking an E351C
    What is going on here? I was able to establish a connection to my E351C through thru network folder in the run box. I loaded it on two of my wireless computers. Everything worked for two days. Now I no longer have permission or the network path is invalid. My wired computer is doing fine. Same path, same machine works fine. I deleted everything and turned off my router, reinstalled all folders and drivers...I no longer have permission to access my SMB folder on the EStudio from my wireless computers. Why? What is denying me. I changed nothing. I can't even access top access thru the IP. What is blocking me? Anyone know?
  • emujo
    • Jun 2009
    • 3009
    Re: Networking an E351C
    Is the shared folder the only thing you can't access...can you see the shared items on the different workstations? Did you install any updates just prior to the failure (could be an auto update). EMujo
    • yormets
      • May 2009
      • 336
      I can't access the printer features either. I can't even get the wireless computer to find the folder. Now it simply does not exist on the wireless network. However the wired computer sees them just fine. Obviously it's not the MFP. It's something in windows. I changed nothing. I even turned my firewall off. Still can't locate it. If I enter the folder address in the run box, it says the path is not found. I may not have permission from the server administrator. What?
      My wireless computers are running on an extender. I can access everything but these two machines. One is an E4511, the other an E351C. They are connected thru a 6 port switch where the wired computer is hooked up. This stuff drives me nuts. How could it have worked fine for two days and then disappear from my wireless network on two different computers one running windows 7 the other XP SP3. I need a drink!
      • yormets
        • May 2009
        • 336
        Figured it out. A bad connection between the switch and the router. Everything is now fine.
