Cd-10
  • rprem
    • 49
    [Error Code] Cd-10
    HI ALL
    In Toshiba655 CD-10 error coming while taking print out any idea about the error code
    Head Lines Are Made When Dead Lines Are Met
  • bauer
    • 72
    Re: Cd-10
    CD10 Process related
    service call
    Cleaning brush drive motor abnormality: The cleaning
    brush drive motor does not run normally when the power
    is turned ON or the copying is started.
    Error code Classification Contents \
    [CD10] Cleaning brush drive motor abnormality
    (1) Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are
    not locked (no extraneous material or toner clod in both the toner transport sections at the
    cleaner unit and recycle toner unit).
    (2) Is the cleaning brush drive motor (M13) disconnected?
    (3) Check if the connector (CN337) on the LGC board and connector pins are not disconnected.
    (4) Replace the cleaning brush drive motor and recycle toner transport motor (M8).
    (5) Replace the LGC board.
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      Re: Cd-10
      Have you checked the waste toner bottle?
      It didn't say that I couldn't do it in the manual.
