can't remember exactly but i believe ya press the "network/printer" button.. find an icon on touch screen labeled "network".. then find one labeled TCP/IP.. change it there.. like i said, i can't remember exactly so if it's not right, don't be too pissed.. lol.. but it should get ya in the ballpark if it's not right.. good luck..
usually it's done through the display panel of the fiery controller, it depends if you have the fiery fitted inside ( under the flap ) or the stand alone tower. you have to scroll down to setup, then find network, etc... it's been a while since the last time i setup the ip on one, so thats the best i can explain for now.
If you know the IP address of the machine now, you could change it from Top Access, but the computer has to be on the same network, and you have to go to adminitration and then network.
PRESS THE USER FUNCTIONS KEY PRESS THE ADMIN TAB ENTER THE PASSWORD IN THE FIELD DISPLAYED THE PASSWORD IS 123456 CLICK ON THE NETWORK TAB CLICK ON THE TCP/IP TAB ENTER THE IP ADDRESS IN THE FIELDS TURN THE COPIER OFF THEN BACK ON TO INITALISE THE SETTINGS ENTERED INTO THE COPIER
there you go job done dont any of you do courses or know anything about machines you working on it helps
can't say i've ever recalled a 310c colour machine having the user functions / admin system i know that all the ebridge machines do but hey. what do i know, i'm only tech support for the manufacturer
For any ebridge or ebridge 2 machine this is the correct way to do it. However the 210c and 310c and the other variations use a fiery controller and this does not work. You have to go to the fiery scroll to setup then network and finally the ip address info to change it.
i hate to say it, but maybe a little bit less sarcasm on a forum where everyone gets along would go a long way
grandma & eggs & suck & teach spring to mind.
I certainly listen & learn on courses, maybe thats part of the reason for having my name in tech news so many times for star awards on courses / providing so many articles of helpfull tips in tech news over the years
