I have a 5540C with a transfer belt cleaning blade making a vibrating noise once in a while. I applied patting powder to the belt, but the noise returned a few hours later. I will be trying toner on the blade next. The copier only has 100K on it. Anyone else run into this problem? Thanks
5540C vibrating noise from TBU cleaning blade
Re: 5540C vibrating noise from TBU cleaning blade
Had same issue with e6520c straight outta the box. Was also causing chatter marks down the page. Seemed to be mainly at start up. replaced tbu blade kit was the long term fix. Tried powder which did last a few days.I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison -
I have a 5540C with a transfer belt cleaning blade making a vibrating noise once in a while. I applied patting powder to the belt, but the noise returned a few hours later. I will be trying toner on the blade next. The copier only has 100K on it. Anyone else run into this problem? ThanksComment
