I cleared all toner from the recycled toner auger, the brush gears and drive gears are cle3an and turning well. When I run 03-115 to turn the motor on I get nothing. My question is this the bard most likely or could it be a fuse? any help? thanks
e studio 853 code cd10
Re: e studio 853 code cd10
Did you clean the gears on the brush drive motor? I had the same problem on a es723. Motor is behind the drum assembly. You can access it from the front. I cleaned these gears and problem was solved. The manual shows how to remove the motor and gear assembly. -
Well I am going to do that now. I was just going to change out the motor. Do I have to remove the motor to clean the gears? I havent opened the manual yet to see if it had the process to change it I was doing that next. I didn't see it prefviously but I really didn't look for that as of yet.Comment
