Toshiba DP8070 Error Code P00 problem
  • gabequintana
    • Jun 2025
    [Error Code] Toshiba DP8070 Error Code P00 problem
    Any suggestions or help would be appreciated. Thanks.
  • bauer
    • 72
    Re: Toshiba DP8070 Error Code P00 problem
    Are you sure that is the error code as I have no such code in the manual?
    • gabequintana
      Yes, I am sure. You can find a brief description on Pg. 177 of the DP4580/5570/6570/8070 Manual Re: Printer Function. I've performed the suggested opertation stated to clear the message, yet it is reoccuring. Thank you kindly.
      • Harry
        • 228
        May a fault connection from printer to sysbord or the printer bord is gon. try to disconnect printer with co pier on if status of led change reconnect. format hd.
        good luck harry
        • gabequintana
          Not exactly sure what you are suggesting, but thanks Harry! I'm able to print for a brief period time aftet I reset the I -O, but the problem eventually returns.
          • gabequintana
            So I don't think The MB or PB is gone.
