E600 Scan
  • Toshiba911
    • 24
    E600 Scan
    Hi !
    Anyone know, how Toshiba E600 to scan in Win7 ? Please help!
  • sdrawkcab
    Confused & Bewildered
    • Jun 2009
    • 317
    Re: E600 Scan
    The first thing you will need is a scan enabler dongle.
    Some days, it's just not worth chewing through the restraints
    • Toshiba911
      • 24
      Re: E600 Scan
      I aready have. In Win XP I can get the file in Fileshare By comand: run:\\Ip adress of the machine
      But in Win7 I donot how to do.
      • emujo
        • Jun 2009
        • 3009
        Re: E600 Scan
        Do a google search for SMB scanning with win7...it's a file and print sharing setting that is off by default in Win7..it could also be a firmware issue...one of the later versions addressed an issue with "Digitaly Signed Communications" that the Ebridge 2 series needed turned on to scan via SMB to newer OS's. Emujo
        • dherring
          • Mar 2012
          • 7
          Re: E600 Scan
          If you are just scanning to the E600 file_share you can make a shortcut on the client desktop by right clicking on desktop and selecting new shortcut. In the box, type in the IP address of the E600 ie \\192.168.0.100\file_share. If you are scanning SMB to a Win 7 client you need to set up a shared folder to scan to and let the E600 login to the client and give the E600 full permission and full security control to folder. If you need more info I may be able to send you the instructions.
          • ss12
            • Jul 2008
            • 289
            To be able to see the share file in win 7, go to top access then admin mode.there is an option there to turn off digital signing.you'll be able to see the fileshare after you do this
            • Toshiba911
              • 24
              Re: E600 Scan
              Thank you for your help.
              I will try by that way.
              • jvargas
                • May 2009
                • 44
                Re: E600 Scan
                other way is using a program that you can find in the cd utilities called download files. it more simple and you do not need an enable dongle for scan, you can download the files directly your computer in pdf, or jpg. try this is very simple
                • SOS
                  • Oct 2011
                  • 46
                  Re: E600 Scan
                  You need to up-date new firmware, when you scan to file window 7 automatic recognize in my computer network, then you can shortcut to desk top
