Does anyone have information regarding new tosh x bridge 2040ce error code f109 /5
help required
Re: help required
I have not seen this particular problem. Toshiba however has started to see the problem and are suspecting that people are not waiting for the MFP to boot up all the way in 08 mode after a firmware update because intakes so long. (sometimes 8-10 minutes)
Might want to reload firmware if you haven't already. -
Re: help required
beware people on the new x bridge they have many quirksComment
Re: help required
The Ebx series due to new platform, software side not so stable compare to Eb3 series...
So far i have 1 customer having this F105/109 issue...
Need to format the HDD and reinstall the firmware in order to up the machine back...After certain period, it happen again...
Currently no ideas what is going wrong with the machine, only suspect that users might not be shutting down the machine properly...Comment
Re: help required
what version of firmware are you using, we havnt had any issues since V3100
also we have been disabling the "Super Sleep" mode which i think was causing some of the freezing issues
Cheers CamLast edited by fourl6; 04-14-2012, 11:11 AM.Comment
Re: help required
Currently we only use firmware V3000... But all the while i dont like this super sleep mode feature, i always disable it when deploying new machines...Comment
Re: help required
ThanksComment
