Remote Scan to MAC
  • bubillchoi
    • Jul 2025
    Remote Scan to MAC
    Does anyone know how to use the remote scan feture on a toshiba 452 to send files on a folder located on a MAC computer ?
    Pleas Help
    Thank you
  • didi2005
    • May 2011
    • 401
    Re: Remote Scan to MAC
    1st u need to share the destination folder on the MAC. U can refer below info for MAC file sharing.
    Mac 101: File Sharing
    U need to make sure the folder is accessible on other pc.
    Go to Top Access, under Save as file settings, on the remote 1, select "Allow user to select network folder to be used as destination".
    Then, press scan button-->scan to file--> enter the network path with correct login.
    Once u able to scan successfully, create a template for your settings.
