How to fix this problem ?
  • Xuanvinhqnam
    • Dec 2007
    • 51
    I have a Toshiba DP5670 copier, I have a problem is that" paper is allway misfed on paper path (It can not move to fuser unit), some time, even if a copy paper is completed output, the misfed on paper path symbol is flashed. Thank alot!
  • Sundog
    Toshiba
    What does the image look like? I had a similar problem with a DP where the developer tank was seized.
    • Xuanvinhqnam
      • Dec 2007
      • 51
      the image has been normaly, I think a paper I used were damp and thin.
      • alexxcopier
        • 53
        check the suction fan and filters
        • Xuanvinhqnam
          • Dec 2007
          • 51
          Thank you, but where is the suction fan and filters place ?
