Toshiba 1370 Dark Copies
  • dunnbiz
    • Mar 2011
    • 13
    Customer used generic toner in Toshiba 1370... now getting dark copies. How can I lighten copies? Ive cleaned optics and rewired coronas.
  • Gregg
    Re: Toshiba 1370 Dark Copies
    05-5 is auto exp adjust. 1 and 7 to adjust up or down. If that doesn't work, time for a developer dump from the toner.
    • dunnbiz
      • Mar 2011
      • 13
      Thanks Gregg; I'm trying to avoid the dev dump.
      • dunnbiz
        • Mar 2011
        • 13
        Gregg: Is that holding 0 and 8 and turning on the copier Gregg?
        • Gregg
          Hold down 05 it will say "ADJ" and then hit 5
          without turning off you can also check cq by hitting 09 and it will go into copy mode to see what your target looks like. then just hit 05 again to re adjust
          • dunnbiz
            • Mar 2011
            • 13
            Thanks Gregg. I haven't done Toshibas for a LONG time, and trying to be a nice guy to my bank.
            • dunnbiz
              • Mar 2011
              • 13
              Or a suck up to my bank is more accurate.
              • Gregg
                No problem, they need to upgrade that shit.
                Work something out in trade like a few savings bonds from the bank and some cash.
                Good luck.
                • dunnbiz
                  • Mar 2011
                  • 13
                  Good luck.
                  I got them about 5 years ago with a Kyocera 3035... and I haven't had a service call yet! My bad!
