I am new to the Toshiba line so still learning.... I have two questions 1) is it possible to upgrade/add memory to the 556 machine or 2) is it possible to utilize the hard drive as RAM to allow for more or larger print jobs to be in queue?
ES-556
Tags: None
Re: ES-556
Edit, if you want your print jobs to spool faster the es556 comes standard with 1gb ethernet, so make sure your router and PC network card are 1gb compatible.
Cheers Cam
