Tosh ES650 duplex cq problem
  • Hansen88
    • 1066
    Hello, the transfer belt does not seem to be cleaned real good even though a new belt, blade and brush was installed. The problem which may or may not be related is when doing duplex copys the front side looks fine but the back side is dirty. Seems as though it is from the transfer belt issue. Anyone seen this problem? Thanks
    Jack
  • SOS
    • Oct 2011
    • 46
    Re: Tosh ES650 duplex cq problem
    You may check fuser unit or developer unit
    • Gregg
      Did you clear the counter in PM support?
