3511 Developer Seals
  • 2new2no
    • Dec 2007
    • 48
    Is there a kit for the seals on the black developer unit. I see individuals 6LA29869000 6LA29870000 & 6LA29921000 I'm also in need of the filler square that seems to dry rot on most of the developers. Any suggestions?
  • emujo
    • Jun 2009
    • 3009
    Re: 3511 Developer Seals
    If your down to replacing seals on the DV unit, then you also need to replace shafts and worn gears...IMO you are better off ordering and installing a new DV unit...the labor/parts cost to refurb (not to mention any problems you induce when you pull all this old crap out and find dry rot around the seals) is more then the replacement cost...Emujo
    • Gregg
      I have a good used one(30k) if you need it.
