as scanning for ususarios in toshiba e 353?
  • ESTANISLAOWENENTON
    • Sep 2025
    hello
    know how to scan for remote
    but the client wants the scanner made ​​will come to different computers not sharing the folder directly as there are confidential documents that he wants to come to certain people only
    appreciate your help
  • emujo
    • Jun 2009
    • 3009
    Re: as scanning for ususarios in toshiba e 353?
    My guess (based on all of your previous posts) is that you may have some experiance on the Toshiba product, but not factory trained, little network experiance ( dealing with MFPs)...setting up scan to folder on these products is pretty cut and dry if you know what you are doing..(again) my guess is you don't have the necessary knowledge..there must be 100+ posts on how to set up SMB scanning on this site...Many techs have taken the time to write down specific steps to assist in setting this up. Between creating the folders, proper sharing, mapping the MFP back to the folders and using the proper credentials, I don't think you are gonna "get there"...I would recommend you call a qualified Toshiba network specialist..pay for the time he/she is onsite and perch on his/her shoulder taking notes and asking questions. Just trying to navigate through Top Access can be confusing..I might also recommend you think about setting up scan to email versus scan to folder as this requires less settings ( and easier to set up). Emujo
      UNFORTUNATELY THE TOSHIBA TECHNICAL ENOUGH IS ENOUGH TO HELP OR envious TEACHING AND IT WILL NOT PAY
      OTHER WISE FOR RICOH TECHNICAL PANASONIC I NEED HELP FROM WHICH WE PRETTY
      SCANNING SYSTEM, PANASONIC, MINOLTA,WORST IS VERY EASY DIFFERENT FROM TOSHIBA
      IN THE LINE TOSHIBAB /N ME FEEL GOOD
      I've gotten NOW IN COLOR AND SCANNER CONFIGURATION IS LITTLE
      WHEN YOU CAN I WILL BE REPORTING YOUR QUESTIONS
      THANKS
      • TheOwl
        • Nov 2008
        • 1732
        Obviously you know that you can only have two Remote locations, but if you remove one of those Remote locations and set it to User Defined, then you can make templates which scan to file using one of the remote locations.
