toshiba 2830C Copier
  • RonMac
    • Oct 2008
    • 57
    [Error Code] toshiba 2830C Copier
    Can anyone tell me what error code C380 is on the Toshiba 2830C Copier? Thanks. Ron
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: toshiba 2830C Copier
    Autp toner sensor error (K)
    Could also be broken charger end block.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • RonMac
      • Oct 2008
      • 57
      Thank you for your help......I will give that a try. Ron
      • RonMac
        • Oct 2008
        • 57
        Thank you for your help....I will give that a try. Ron
