error CD20 on toshiba 600
  • johan008
    • May 2012
    • 5
    [Error Code] error CD20 on toshiba 600
    HI guys I know I only joined 2 min. ago but I am realy battling with this error.(CD20)
    I have cleand out all the toner feeding augers on the used and the recycle units and I have tested the motors and all is working, and I have tested the toner bag full detection sensor, also working so if someone knows the fix to this please HELP!!
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: error CD20 on toshiba 600
    On the back of the machine (behind the top of logic pwb) is the waste auger. On the left side is a photo sensor. Check the auger is not blocking this sensor. Also make sure this sensor is working.
    • JustManuals
      • Jan 2006
      • 9932
      Paul@justmanuals.com
      • johan008
        • May 2012
        • 5
        @Mr Spock I did check it and the waste auger is not interrupting the photo sensor and i did test it and its working.
        Yesterday we tested the machine and now its giving another code CD30 and still giving CD20 so how is this possible??
        We can make a single copy through the bypass and once the copy has gone through it gives the error CD20.
        So my Q are why will the machine give two different errors on two different places in the machine
        CD20 waste toner auger/motor
        CD30 recycle toner auger/motor
        • Gregg
          Check the assembly in the front, Ive seen cracked white drive gears from the auger binding up in that thing.
