toshiba e-282 hanged out
  • sjinachandran
    • Aug 2025
    Dear friends,
    Toshiba e-282 getting ready but i cont make a copy, even i press the print button i can hear the beep sound but the copy not made.
    In Scan option the bulk files are saved, how to delet all the files. (i had a doubt the first problum presist due to bulk scan files are saved inside the sacne option)
  • lenatec
    • Oct 2011
    • 46
    Re: toshiba e-282 hanged out
    Originally posted by sjinachandran
    Dear friends,
    Reintialize of system board 08+665 and intialize if work ok, if not load a firmeware for the machine
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • iD10T Debugger
        • Jun 2012
        • 15
        Sounds like the hard-drive is full. I recommend getting a handbook from Paul at Just Manuals so you can reformat the hard drive. Another issue I also found was the thermistors had enough build up on them to cause a delay in printing. You may want to check that also. Good Luck.
        • emujo
          • Jun 2009
          • 3009
          I would save the initialization as a last resort...this usually induces other problems ( meter reads in excess of 2 million for one)..Replace the HDD and get the MFP to the latest firmware before you do anything more drastic. Emujo
          • jamesyboy
            toner monkey
            • Jul 2010
            • 188
            yOU COULD CLEAR THE FILES IN TOP ACCESS IF NOT GO FOR IT FORMAT THE HDD 08-690
            • TheOwl
              • Nov 2008
              • 1732
              \\IPaddressofthemachine\file_share
              Got to that UNC path from a computer and then delete the files that you don't need.
