Automatic Function Clear & Toshiba e-Studio 550 / 650
  • free
    • May 2010
    • 6
    Is it possible to increase the time or deactivate Automatic Function Clear?
    I read the following in the manual (page 1-5 or page 20 in pdf):
    Even if you do not press the //FUNCTION CLEAR
    key, within the specified period of time after copying is
    finished or after the last key is pressed in a copy
    procedure, the automatic function clear mode will work
    to clear all settings to defaults, and the basic screen
    will be displayed. While the department management
    function is being operated, the display returns to the
    department code input screen.
    Thanks in advance.
  • TheOwl
    • Nov 2008
    • 1732
    Re: Automatic Function Clear & Toshiba e-Studio 550 / 650
    From memory, I think it is a service code to increase the time out period.
    You will need the Service Handbook for this and not the User Manual. Find Manuals4You as he has a huge range of service manuals avaiable, but make sure you get the Service Handbook.
    • Gardner
      • 7
      Thanks in advance.
      (0-8) code 204 start
      Timer to return the machine to the defaultsettings when the [START] key is notpressed after the function and mode wereset0: Not cleared
      1 to 10: Set number X 15 sec.
      • free
        • May 2010
        • 6
        Exactly what I needed.
        Gardner, thank you very much for reply.
