Toshiba e 282 can not display
  • minhkhanh
    • Oct 2008
    • 60
    When you turn on the fan noise is heard. But the display is dark
    I tried replacing and identify errors in sys board
    help me find errors parts to replace on board
    Thanks all
  • TheOwl
    • Nov 2008
    • 1732
    Re: Toshiba e 282 can not display
    Does the engine go through any of the warm up stages or at least rotate the drum when you turn it on?
    If the machine isn't going through the normal warm up stages, then you could have a faulty power supply.
    • minhkhanh
      • Oct 2008
      • 60
      I confirm that errors in sys board
      • emujo
        • Jun 2009
        • 3009
        How, exactly, did you confirm the error was on the system bd? By swapping them? If so, there are no servicable parts (other that NVRAM/RAM modules)..if it's working then your done...throw the bad board away...if you need to know specifcally what is wrong with the board send it to HYTECH...Emujo
        • iD10T Debugger
          • Jun 2012
          • 15
          Do NOT try to swap more than one board at a time or you WILL put the machine into a state that only a Toshiba technician can undo. This has to do with the counterfeiting protection built into the copier. Don't blindly swap boards, and if you didn't already know that, you really need to get a certified tech to repair the copier.
          • emujo
            • Jun 2009
            • 3009
            Clarification....the problem happens when you replace more than 1 board at a time and try to put the boards back into the MFP they came from...If you are using a working MFP to trouble shoot, then it's critical that you swap 1 board, if it doesn't fix the problem remove and put the board back into the original MFP and power it on/off...But I agree with Ppistulka, this sounds like you're over your head...call a Toshiba tech. Emujo
