Toshiba 3500C
  • copiman
    • Sep 2011
    • 861
    Toshiba 3500C
    I need to replace the Black PCU unit. On page 104 of the parts book it shows a PCU unit and a bottle of developer inside a square box. The part number says it is 6LE39005000 and the description says EPU-FC35-K. I'm now beeing told that is an invalid part #. Can anyone tell me where to find the correct # and what is the correct #?
  • iD10T Debugger
    • Jun 2012
    • 15
    Re: Toshiba 3500C
    This is the first or original number 6LE23638000
    Then a revision was released 6LE39052000
    And the latest revised one is 6LE23638000
    So, when ordering use 6LE23638000
    PS, your number is missing a 2 and has an extra zero (6LE39005000) so you were looking at the second revision.
    • bauer
      • 72
      Re: Toshiba 3500C
      If you are replacing the developer unit then you use PART # 6LE23638300 or the developer kit that includes the parts to rebuild your current dev unit use PART # 6LE39048000
      6LE23638300
      EPU-FC35-C
      Replaces: LE39052300
      6LE39048000
      DEV-KIT-FC35K
      Replaces: LE39000000
      • TheOwl
        • Nov 2008
        • 1732
        Re: Toshiba 3500C
        Definately get the K Dev Kit as well as a new Drum which will result in a brand new Image Unit.
