3tech
  • tritech
    • Jun 2025
    3tech
    How do I turn on the fax transmission monitor on e853 to monitor busy or wrong numbers?
  • emujo
    • Jun 2009
    • 3009
    Re: 3tech
    Look on the control panel around the keypad..the # key is also the "Off Hook" key in fax mode..I assume you want to listen to the sequence when you fax...Emujo
    • tritech
      Re: 3tech
      Thanks for this Emujo, but I need to turn it on permanently. I did it once in test mode 08 but I can't find the sub code.
      • jim v
        • May 2008
        • 41
        Re: 3tech
        Try going into 1 & 3 mode sub code 338 & make it a 1.
        • tritech
          Re: 3tech
          Thanks Jim, I'll try that.
