Es:3510 edit options
  • JVC
    • Jun 2011
    • 151
    I have a toshiba 3510 that has most of the buttons in the edit tab grayed out. I know that when you select some options ones some that will gray out but that is not the case here. Thanks for any help.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Es:3510 edit options
    The login that you are using may not have rights to change these settings. The configuration of the copier may be incorrect. Or the driver is not the correct one.
    • JVC
      • Jun 2011
      • 151
      I'm not sure if I explained what is happening. We recidved in some es3510 used machines. When I turned the machine on and press the edit tab
      most of the icons are grayed out. Some of them are, image shift, edge erase, book center erase and so on.
      • arnh79
        • 469
        If you are in "black" mode, some edit options are grayed out. Select "color" and go back in edit menu and they will be available.
        Why does every customer think they're the first one to ever say: "you've been here so much we should get you an office, ha, ha, ha"?
