Toshiba eStudio 202L SMTP Client issue.
  • Starblazer
    • Aug 2025
    Hello all,
    I have a Toshiba Estudio 202L that is giving me issues. I disabled all unneccisary network servers on the "Network" page on the Topaccess server and set my SMTP client server address. I click "ok" then "save" and get the "network unit is rebooting" message. A couple minutes later, the topaccess server comes back and everything is great until the power is lost.
    Once the power is lost, the only setting that has gone missing is the SMTP server. I have it set up at smtp.gmail.com. If I set it up again, the unit works perfectly until the power is lost again.
    Any clues?
    Here are the specs from the TopAccess setup page.
    Printer Manufacture TOSHIBA
    Copier Firmware Version T377SY0U355
    Copier Main ROM Version 377M-06
    Copier Scanner ROM Version 377S-03
    Thanks in advance,
    Adam
  • BrMize75
    Re: Toshiba eStudio 202L SMTP Client issue.
    I wish I had a solution to your issue, unfortunately I don't.
    What caught my eye is that you are using gmail as your SMTP Client.
    I am trying to do the same thing with my eStudio 202L but I can't get it to send anything.
    Can you share with me your network settings?
    I know I must be missing one simple thing to make this work, but I can't figure it out and can't find any solid help on this issue.
    Thank you.
    • emujo
      • Jun 2009
      • 3009
      Try replacing battery backup, might be depleted. Emujo
