e studio 230 error c260
  • SOS
    • Oct 2011
    • 46
    i have e-studio 230 working fine, when i move to different location, machine show up error c260, i checked scanner seem likes normal.
    anyone help
    thanks
  • jvargas
    • May 2009
    • 44
    Re: e studio 230 error c260
    Peak detection error: Lighting of the exposure lamp
    (white reference) is not detected when power is turned on Check the glass and the flex of the exposure lamp, or the lamp, maybe this help
    • jvargas
      • May 2009
      • 44
      [C260] Peak detection error
      Does the exposure lamp light? (Perform the output check in the test mode: 03-267)
      YES
      1) Check if the connectors on the CCD and SLG boards are disconnected.
      2) Check if the shading correction plate is dirty.
      3) Check if the conductor pattern on the CCD board is short circuited or
      open circuited.
      4) Check if the conductor pattern on the SLG board is short circuited or
      open circuited.
      5) Replace the lens unit.
      6) Replace the SLG board.
      NO
      1) Check if the connectors of the exposure lamp and inverter are disconnected.
      2) Check the SLG board if the connector pin CN9 is disconnected and the harness is short
      circuited or open circuited.
      3) Check if the conductor pattern on the SLG board is short circuited or open circuited.
      4) Replace the SLG board.
      5) Replace the inverter.
      6) Replace the exposure lamp.
      • JustManuals
        • Jan 2006
        • 9919
        Paul@justmanuals.com
