Error E030 just refuses to go away!!!
  • same_steven
    • Jun 2011
    • 52
    Hie frds,
    I have an Est 230 that is displaying error E030 that just refuses to go away.
    I have checked everywhere there is no paper jam.
    I have cleaned the registration sensor and serviced the machine entirely.
    What could be bothering it?
    Your responses would be highly appreciated.
    Me again,
    Same Steven
  • JustManuals
    • Jan 2006
    • 9838
    Re: Error E030 just refuses to go away!!!
    Paul@justmanuals.com
    • didi2005
      • May 2011
      • 401
      I will recommend u to perform input test & visual check on below sensor and actuator...
      Registration sensor 03-[FAX]ON/[2]/[A]
      1st transport sensor 03-[FAX]OFF/[6]/[E]
      Exit sensor 03-[FAX]ON/[2]/[B]
      Normally for e230/232, the exit actuator easily broken...
      • peterxu256
        • Jul 2014
        • 110
        back to old topic, Doing "Registration sensor 03-[FAX]ON/[2]/[A]" but it highlighted "H"----Upper Drawer tray-up sensor(tray at upper limit position,
        Also doing other twos, all highlighted "H" Just want to know which sensor tricked the code. LCD indicated the location look like Registration or PFP uppreer drawer feed senor.
        any suggestion is great.
        • riyadh hossainbd
          • Dec 2015
          • 239
          change 1) "Registration sensor 2)1st trans sensor together
          • peterxu256
            • Jul 2014
            • 110
            Thanks, Will try. But could you explain the real meaning of "H" ?
