estudio 2540c turn off energy saver
  • waqas_pk
    • 18
    hi,
    i recently installed new toshiba estudio 2540c color copier but machine automatically turns off after a short time i need the program to turn off auto shutoff and energy saver. i already tried 08-205 and 08-206 but machine is not taking these programs.
  • didi2005
    • May 2011
    • 401
    Re: estudio 2540c turn off energy saver
    08-9113 set to 1, to display the settings on the admin tab.
    • Travis06
      Tech.
      • 193
      Yeah, those machines and all the ones that follow do not use the old 3 digit codes for 08...ect. So you will need a new manual, cue the JustManuals advert!
      • waqas_pk
        • 18
        thanks to all seniors for reply.i'll try the code.thanks again
        • toantam
          • 63
          You can use topaccess setup this function.
          • didi2005
            • May 2011
            • 401
            Wonder why didn't toshiba release firmware that include the energy saver button to be visible under admin tab instead of manually enable it....
            And those annoying slit glass maintenance & PM message...Always need to manually disable it when deploying new machine...
