toshiba estudio 350 printing image quality
  • b1406
    • May 2008
    • 51
    [Misc] toshiba estudio 350 printing image quality
    Hello
    Hope any body can help
    I have this toshiba e-studio 350 and I have printer image quality trouble with it
    the page background is dirty it have grey strips on in when I use it as copier everything is fine
    the page is clean no dirty strips or anything
    can it be fixed
    thanks
  • JustManuals
    • Jan 2006
    • 9838
    Re: toshiba estudio 350 printing image quality
    Paul@justmanuals.com
    • michaelc
      Field Tech
      • Mar 2011
      • 590
      Is this problem with the print or copy/print. Have you looked at the drum,dev and charger units?
      It didn't say that I couldn't do it in the manual.
      • b1406
        • May 2008
        • 51
        this happens when it prints from pc.
        I dont think there is something wrong with drum,dev,etc
        because when is making photocopies everything is fine.
        I thing it may need some adj. with code I tried some but no result
        • michaelc
          Field Tech
          • Mar 2011
          • 590
          If the photocopies are fine but the prints are not, could it be the print job itself. Have you tried it on a different machine. What type of document are you printing word, pdf etc.
          • b1406
            • May 2008
            • 51
            Yes I have tried on another machine the document is fine
            only when prints from pc this happens. when I make copies is fine no smudged background
            this happens in printing I have tried to fix it by AJ code but no success
            is there any particular AJ code for printing function
            thanks
            • jamesyboy
              toner monkey
              • Jul 2010
              • 188
              Have you reset the network card 08-693 and i would failing that format the hdd 08 690
              • michaelc
                Field Tech
                • Mar 2011
                • 590
                Is it only this one print job causing a problem are do all print jobs have the problem. Is it a specific file type such as ms word or pdf. If it is just one print job causing the problem I would not adjust the print quality settings as you will knock the machine out for all other prints.
                Do you have an example of the problem ?
                • b1406
                  • May 2008
                  • 51
                  the problem is with all print files even with test page from printer properties I tried to change printer driver
                  so this happens with all file formats
                  I tried to fix it by AJ codes related to printer image quality on SM book I used 0-5 672 4 and try to increase and decrees the print density but the image come the same is not lighter or darker.
                  • michaelc
                    Field Tech
                    • Mar 2011
                    • 590
                    If the image quality is poor even when printing from the machines memory (print properties page) then I am unsure as I would assume that if the image is poor from there then the copies from the machine would have the same problem. There are many things I would check on these machines for cq problems. What have you checked/cleaned/changed so far.
                    Adjusting codes is usually a last resort for me. The machine changes its voltages to compensate for wear on parts inside the machine.
                    • b1406
                      • May 2008
                      • 51
                      the image is not poor
                      the print was not from machine memory but from PC test page, printer properties so this excludes the file format from PC any way I tried PDF,Word,Excel.
                      it have background black strips on it, it is like the drum cleaning blade dirty, this does not happen in copy
                      process, in copy process is perfect, I have changed drum unit, developer unit, corona unit, took them from another working copier that prints very good, still the same then I thought maybe it needs AJ code to fix it
                      and try them to no success.
