e350 hd
  • esam ramadan
    • 199
    e350 hd
    e350 gave me f101 i replaced the hd from another and it now working but it doesnot print and don't shutdown
    thanks for any help
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: e350 hd
    did you update the firmware? You may have mis-matched firmware causing this.
    • jamesyboy
      toner monkey
      • Jul 2010
      • 188
      Re: e350 hd
      c/3----3 then install firmware
      • canonbundy
        • Jun 2012
        • 607
        Re: e350 hd
        Yep, Mr Spock is correct, the F/W needs to match System, HDD and Engine then 08-947 and 693 then Admin (123456) - Network and set the correct I.P. Address - should work, otherwise NIC Card needs to be Factory Reset - failing that, replace NIC Card & start again.
        • esam ramadan
          • 199
          Re: e350 hd
          thanks everybody
