Toshiba E-Studio 166/167 Network initialization.
  • copiertech
    • Oct 2010
    • 55
    [Misc] Toshiba E-Studio 166/167 Network initialization.
    Dear All,
    Need your expert advice on the following:
    When ever we install the network card on Toshiba E-166/167 it will just give Network initialization..... and stuck.
    the same card work fine on other machine.
    Any solution for this error...
    thanks
    Waleed
    Waleed
    Copiertech
  • aligis
    • Jul 2010
    • 56
    Re: Toshiba E-Studio 166/167 Network initialization.
    try to update firmware,,, and try it..
    Originally posted by copiertech
    Dear All, Need your expert advice on the following:When ever we install the network card on Toshiba E-166/167 it will just give Network initialization..... and stuck. the same card work fine on other machine. Any solution for this error...thanksWaleed
    • didi2005
      • May 2011
      • 401
      Did u performed the 08 cod for printer kit initialize?
      • copiertech
        • Oct 2010
        • 55
        Hi,
        I did not, I did check for the code in the 08 but I can't find it???
        Do you have it??
        Thanks,
        Waleed
        Copiertech
        • didi2005
          • May 2011
          • 401
          Hi,
          Do you have it??
          Thanks,
          08-669 General System All-clear (Initialization of system NVRAM realm)
