toshiba 600 code c443
  • remielee
    Technical Analyst
    • Mar 2010
    • 140
    hello guys, can i ask for some advice about my problem of toshiba 600 error code c443 i try to reset in the service mode, 08-400 the value is 3 sometimes 6 and make it 0 then enter or interrupt. i already try to replace fixing assembly, control board, i check the voltage out put from power supply 210volts going to the fixing connector, i check also the connection from fixing to the copier clean it, i try to check also the harness and its okie, so guys if you already encounter this kind of problem can you help me.. thank you in advance and more power guys. godbless to all
  • jamesyboy
    toner monkey
    • Jul 2010
    • 188
    Re: toshiba 600 code c443
    check harness that runs throutgh the duplex to the lower main connector they get loose from the ih board hinging down
    • remielee
      Technical Analyst
      • Mar 2010
      • 140
      thank you very much sir for the help, the machine is already okie electrical problem they use extension although when i test it with the multitester its same 210volts when the machine runs it drops to 209volts using extension unlike when i put the power cable directly into the outlet the 210volts remains still when the machine turns on. thanks a lot for the effort and aditional idea. more power sir..
      • canonbundy
        • Jun 2012
        • 607
        check for something as silly as a small piece of paper in the fuser connector at the rear of the machine.
        • esam ramadan
          • 199
          i saw this problem before and after replacing and cleaning it solved by formatting hd
