eStudio 352 w/ MJ-1022 finisher - C580 error code - more than just IPC board change?
  • Daddy-O
    • Jul 2025
    [Error Code] eStudio 352 w/ MJ-1022 finisher - C580 error code - more than just IPC board change?
    Evening all - I'm working on an eStudio 352 - previous finisher (don't recall the model) was damaged so we replaced with an MJ-1022 - changed out IPC board with one from a 350 that had same finisher (MJ-1022) - still getting C580 error code. Is there anything else that needs to change with the finisher model besides the IPC board?
    Thanks for any and all suggestions!
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: eStudio 352 w/ MJ-1022 finisher - C580 error code - more than just IPC board chan
    08-1812 I think change from 0 to 1 or vice versa
    • Daddy-O
      Dammit Spock, I'm a PC tech, not a copier tech! Sorry man, bear with me, I'm admittedly out of my league on this machine, but like to think I can figure out enough on the fly to get stuff working again. Thank you for the response, but can you dumb it down a smidge more for me? Are you saying I just need to tweak a setting somewhere to get it to recognize?
      • Mr Spock
        • Aug 2006
        • 2064
        dumb as I can get... Oh wait I am already that dumb...
        turn off copier
        hold 0 + 8 keys while turning on
        keep holding 0 + 8 until service mode comes up
        enter 1812 on keypad then start button
        display will have either two 1 or two 0 on it
        change the right hand number to the other
        press the enter button on touch screen
        power off machine
        wait 20 seconds then power on machine.
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • Daddy-O
            Right on, I'll give it a shot tomorrow and see if that does the trick. Thanks!
              Try
              08-1912
              • Mr Spock
                • Aug 2006
                • 2064
                try what skynet posted same procedure but different location.
                • Daddy-O
                  Can't thank you both enough, used 08-1912 and she fired up like a champ. I bow to the masters! Enjoy the rest of the weekend, I know I will (now)!
