Hi guys,i came across this error on the above machine and could not proceed.Any clues to this problem will be appreciated thanks in advance.
ERROR F10 ON E-STUDIO 35
Tags: None
Re: ERROR F10 ON E-STUDIO 35
[F10] HDD Initialization error
(1) Initialize the HDD. (mode (08)
n code"690" n 2)
(2) Check if the HDD is mounted.
(3) Check if the specified HDD is mounted.
(4) Check if the connector pins of the HDD are bent.
(5) Check if the power supply connector is disconnected.
(6) Check if the connector J111 on the SYS board is disconnected.
(7) Replace the HDD.
(8) Replace the SYS board.
(9) Replace the harness.
Kinda of a older model there, may also need firmware.
Paul@justmanuals.comComment
