toshiba e207
  • shaungovender
    • Jan 2025
    [Electrical] toshiba e207
    hi can anyone help the toshiba e207 just switches off and comes on again by itself.anyone encountered this problem before please advise.
  • JustManuals
    • Jan 2006
    • 9919
    Re: toshiba e207
    Paul@justmanuals.com
    • TheOwl
      • Nov 2008
      • 1733
      Re: toshiba e207
      Have you checked the power saving schedule from the web interface?
      I think these machines can be set like their bigger counter parts to turn off at a set time and back on again at another time.
      • shaungovender
        Re: toshiba e207
        it seems to turn off and on only when im trying to make a copy,i can have the machine on for a while and nothing happens.
        • shaungovender
          Re: toshiba e207
          please please can anyone out there help me im gettin desperate now.
          thanks shaun
          • TheOwl
            • Nov 2008
            • 1733
            Re: toshiba e207
            Sounds like it could be a power supply issue, but if you are getting desperate, then I would suggest that you get a trained tech in to look at the issue.
            • shaungovender
              Re: toshiba e207
              thanks for the reply,i already had a technician have a look at it.he changed the mainboard about a month ago,now when i call him in the check it he says its the toner.he`s talking a lot of crap cause i think he doesnt want to cover under his warranty.i have a bit aof technical experience with radios and computers so im trying to apply that here.i`ll check the power supply,but i need a service manual.
              • didi2005
                • May 2011
                • 401
                Re: toshiba e207
                I've 1 case with similar problem...
                So far found that is charging issue resulting the machine restart when copying...
                For temporary solution, try removed the process unit, u will see a spring in the machine which touching the developer tank.
                Remove the spring and put back the process unit, the machine should be working, but the printout not so solid back compare to previous...
                • shaungovender
                  Re: toshiba e207
                  thanks i`ll try that.will let u know how it goes
                  • didi2005
                    • May 2011
                    • 401
                    Re: toshiba e207
                    Ends up replaced whole process unit ~~~
