Toshiba e-230
  • nıke-reebook
    • 50
    Toshiba e-230
    When I pull the drum unit in each working copy.
    What could be the reason?
    Can you help.
  • emujo
    • Jun 2009
    • 3009
    Re: Toshiba e-230
    When you post a question, you should at least make some attempt at making some sense...I have no idea what you're asking..Emujo
    • bojans
      • 1313
      Re: Toshiba e-230
      Can you help.
      • JustManuals
        • Jan 2006
        • 9838
        Re: Toshiba e-230
        Paul@justmanuals.com
        • nıke-reebook
          • 50
          Re: Toshiba e-230
          • Originally posted by emujo
          • I did not know could be errors in translation to English.
          • 1)The toner ran out
          • 2)I put a new toner
          • 3)Photocopying'm (Mind if I take a blank paper even)
          • 4)Then, an article on the Web(WAİT ADDİNG TONER.DO NOT OPEN THE FRONT COVER)
          • 5)have reduced my opinion Developer(but not 70 000)50 000 in
          • the Waiting for your help
          • nıke-reebook
            • 50
            Re: Toshiba e-230
            It gave a new warning to:İnstall new toner cartridge
            (I have ordered a new one fit over the toner may not have provided)
            • emujo
              • Jun 2009
              • 3009
              Re: Toshiba e-230
              I still can't make any sense of what you're asking...why don't you post your issue in you're native language...Maybe someone who speaks this and english can help with what your problem is..Emujo
              • bojans
                • 1313
                Re: Toshiba e-230
                I believe he's talking that his machine has message "Please wait, adding toner"
                First I would check if you have clean path on toner cartridge. People sometimes forget to remove protective film off from the toner cartridge.
                Second I can remember that had problem with faulty toner sensor.
                • savi0r
                  • Sep 2010
                  • 363
                  Re: Toshiba e-230
                  Like bojans said, check the cartridge first for any forgotten protective tapes. In the back of the cartridge there is this small gear. It happened to me in the past that the gear either popped out entirely or just a bit but enough to not activate the adding toner mechanism in the cartridge. If all this is ok, move to the imaging unit. Check all gears, make sure there aren't some hard pieces of toner somewhere along the path that block the adding of new toner, clean the residual toner under the cleaning blade. If you checked all this and it's ok, try ading toner manually to the developer station. If the message dissapears, then the toner from the cartridge somehow doesn't reach the developer station. Btw, did you check for any spilled toner around the imaging unit?
                  • nıke-reebook
                    • 50
                    Re: Toshiba e-230
                    Thank you for your answers
                    • I found the problem
                    • I bought cheap toner
                    • was damp
                    • fluid is not(bottle molt)
                    • jonezy999
                      just one copy??
                      • Feb 2010
                      • 952
                      Re: Toshiba e-230
                      • was damp
                      That's just fantastic news mate.
                      Thumbs up!!!
                      I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                      • savi0r
                        • Sep 2010
                        • 363
                        Re: Toshiba e-230
                        It's a known fact that toshiba is very chosy in regards of the toner. I'm not even willing to experiment with other brands except katun and genuine toshiba. Just curious : what kind of toner did you used?
                        • nıke-reebook
                          • 50
                          Re: Toshiba e-230
                          El****c
                          • savi0r
                            • Sep 2010
                            • 363
                            Re: Toshiba e-230
                            El****c
                            Got it. Thank you. This is a good fact to remember in the future.
