Old Toshiba 2080 Analog registration codes
  • Doug James
    • Jan 2012
    • 935
    The lead edge registration is off about 3/4 of an inch. Does anyone remember the 0-8 code to adjust this.
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: Old Toshiba 2080 Analog registration codes
    I thought it was (05)-53 for the cassette @ 100% def 20 range 0-40
    54 " " 200% def 8 range 0-15
    55 50% " "
    An increase of "1" shifts the image towards the lead edge by 0.8mm
    Also have SFB (05)-56 and ADF (05)-58 both at 100% with the same values of def and range as 54 and55.
    Hope this helps.
    0+9 to exit test mode to check output. 0+5 to return again for further adjustment.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • Doug James
      • Jan 2012
      • 935
      Wow too cool, Thankyou so very much... Such a big help...
